Latest Firmware & MOL3 (only) Failing Hardwired (only)
  • This Formuler had been working until latest update. Now it only works over Wifi when using MOL3. A Playstore sourced internet test reports LAN full speed access and no errors, and the "PlutoTV" app works just fine too. MOL3 only spins when attempting to stream TV.
    Interestingly, it's been doing some weird things since the update, and for a time I thought it was having an issue w/a thumbdrive. In fact, the formuler had, for 2 days, worked over Ethernet once I removed the thumbdrive. Today, now that I installed a new USB3 thumbdrive, MOL3 cannot stream TV shows using the Ethernet port - It just sits and spins. Doing a shut-down and removing the thumbdrive solves nothing. MOL3 can no longer play over the ethernet port. It can over Wi-fi, and again all other apps are fine over Ethernet. Only MOL3 is failing over Ethernet.
    I've also re-connected my Z8Pro. It too works just fine over the same wire and switchport. Mind you I've replaced the wiring anyway. Still won't work.
    Device: Z11 Pro
    Firmware: V11.3.5
    Launcher: V12.1.10
    IPTV version: V12.1.18
    Current Service Version: V12.1.10
    Current Storage Version: V10.10.31
    System Formuler Z11 Pro Max
    Software update reports this is latest version.
    Thoughts? Suggestions?
  • Please try to change your ethenet IP settings to either DHCP or Static depending on your current setting. You can access it from Home screen > Settings > Network and internet > IP settings.
    If the issue remains, please provide a video that shows the exact issue for further investigation. You can upload the Image/Video file here: https://streamable.com/ > Upload file > Copy link > Paste the link with your reply.
    In the video, please show the differences when MYTVOnline 3 is connected via wifi, and ethernet.
