Fast Forward and Rewind feature
  • I'm not sure if this is the right place to post a feature request?
    Can we get the fast forward, and rewind features for recordings and time shifting back that you have with the Z8 and Z10's using MyTvOnline 2?
    The limitations with MyTvonline3 and the newer devices to only be able to jump in intervals and not have a true fast forward and rewind where you can see what you're doing is a huge step backwards.
  • I agree. A step backwards to remove the fast forward/fast rewind in MOL3. I use this function a lot on my Z8, so was disappointed to find it missing on the Z11 pro max.
    I downloaded Kodi Player to playback my recordings. This allows proper FF option. It also allows user defined & independent jump forward/backward.
    Edited once, last by FoxRadio: spelling (January 17, 2025 at 1:32 AM).
  • Hi, I downloaded first Kodi and then VLC player to get rewinding/fast forward of my recordings. But unfortunately, when I play the recordings in these players, they get split in 30 min segments and often don’t even play in correct sequence. Does anyone have a suggestion how to get that fixed? TIA.
