How do I create a QR code on my FORMULER Device to setup my account on MYTVOnline+
  • Hello,
    I am trying to configure my account on MYTVOnline+ using the QR Code option.
    It workls perfecly using MAC-ID, Xtream Codes and M3U.
    However, there is a "QRCODE" option and I don't kow how to link it to an MyTVOnline 2 or MYTVOnline3 sources already setup.
    Then only QR CODE generated by my Formuler products is the one to download the app MYTVOnline+ on Android or iOS.
    Can we generate a QR CODE on a Formuler device we can scan from our Smartphones/tablets to setup automatically tha account in use?
    Thank you very much
  • Mytvonline3, menu, Contentmanager,
    Then select your portal and the button above with the arrow up, if you click on that arrow (next to delete portal) its should generate qr.
    Is that what you mean?
  • It is indeed and it works perfectly !
    Thank you very much for that!
    Do you know if it works also with MYTVOnline 2?
    AND...last questionif I may...if the account is tied to the MAC addresse on on the FORMULER Device, does it work too? Or the Xtream codes are way safier?
  • I didn't test it my friend.
    Xtream codes api is safest way what i now. Macid isnt safe enough providers sayn
    But maby there is a option to change macid in the one from your box.
    And If you contact your service provider and tell them to convert your mac to Xtream. Its possible.
