I have a Formuler Z11 Pro Max with File Manager + app installed (from Google play store).
I setup the app to look at files on my Google drive account in cloud services. I was watching stored content from my drive with no issues. All of a sudden it stopped working.
Now when I try and access the drive through the above mentioned app, it keeps saying "Could not connect,,,"
I've tried doing rhe following:
-Cleared cache on app
-Removed cloud account (google drive) and re added
-Restarted z11 box many times
-used vpn to try and connect
-tried other apps to see if it connects
-side loaded Google drive apk and tried accessing through this, no joy
Prior to the z11 box I had a xiaomi box and had the same problem. I thought it might be something to do with this box so I decided to switch to the formuler z11. As mentioned above, the difference between xiaomi and the z11 is that Google drive (through file manager app) worked for a while on the z11 whereas the xiaomi box never worked from the get go.
As me turned above I tried side loading Google drive apk and when I do this, it simply doesn't show any content saying "could not refresh"
If anyone knows why Google drive is not working please help as it would be very helpful to have this working.
Thank you.
