Keeps disconnecting from my TV online2
  • Keeps disconnecting after a couple hours use. When you go to change, the channel will go to black screen. Then when you try to reconnect, error code 7 comes on. Happens with every box in the house and on my mobile. Sometimes will take six hours to 24 hours to reconnect.
    Some providers throw you out after 8 hours watching one channel. Some users let box on and after 8 hours not changing channel, provider throws you out then so they save bandwith.
    Normally you should restart and reconnect again without troubles.
    6 to 24 hours to reconnect? Geez!
    Do you have a iptv provider with multiple connections? Or paid for 1 connection and installed it on all you devices? If you did that and let all your devices on, the channels will blinking on all devices and you will be blocked for some hours or forever!
    What for iptv connection you bought? 1 line or more lines? (dont mention any provider names on forum before you do:winking_face:)
    But if you bought 1 line and installed it on all your devices its highly possible you get blocked. Normally its a permanent block. But you can reconnect after 7 hours - 24 hours.
    Waiting for your answer:raised_back_of_hand:
    Edited 2 times, last by Lucky133 (February 27, 2025 at 10:17 AM).
