Posts by Stefansteif
I really love the Autoupdater. Its perfect for my family. And i think i should be implemented in the installation process of MOL 3 after the Channel/ VOD / Series (tick on/off) screen.
Maybe its possible the devs can implement up to 4 times refresh.
Many providers change the Channel Name during the day for Live TV or Live Events.For Example
1. Refresh: 10:002. Refresh: 15:00
3. Refresh: 18:00
4. Refresh 20:00
Or whatever time the user chooses.
for some „older“ users, or not so technician users it is more convenient when its automatic , what i really love for my users, that this function exists. Even people said, its complicated to refresh the list.
and when its possible to do it more often a day. Would be good addition. -
Hi Sam, thanks for the own thread
Suggestions:
- Fav Teams
- More Leagues
- More Sports (F1, Boxing, UFC...)
- Live Notification for Goals-Reminder for Start of Game (15min 60min )
- Highlights from Youtube (Maybe you look into One Football)
- Turn Off / Mute Notifications at the notification direct - because IPTV Streams are often behind the goal
- Selecting favourite TV-Countries.
-if you german - then i can select: TV Stations from Germany, Austria, or England, Italy ... - that i get only results of the TV Stations from this country for this specific Game, or Event, or League
- Small Interface which can be opened from the action menu (where all the settings are at the bottom when you watch a channel) - and stays on the screen (transparency level to change too please
-Live Statistics from the Game
-Other Results from the Same League other Favorite Games
. -Quick Zap on the other favourite game
Thanks for this feature - its really outstanding !! -
Dear SAM , maybe we can have a own thread for Game Time, where we can help the team. Or have suggestions to improve the Game Time Feature.
I think we have a lot sport/ football freaks here
It really works like you said.
Just if you say nothing it stays „forever“After restart of box its gone.
SAM can i just ask, how do you guys make these screenshots and share them. Cheers
I will try. Thanks.
The green dot should show when using the mic button on your remote.
Ok thank you. I just pressed this once. It stays now for days 😂 maybe i press the google button again.
Maybe you can switch it to orange. Like on apple devices to show the user that the mic is active. -
Hi, what does this mean?
Thx -
Because the other thread is closed I come back with this issue.
We changed back to FORMULER --> and its working now. So there is no problem, with startup and then no sound.
How can you now solve the problem, because as i said before, intention from BT1 Remote is, to have only one remote.
Do you need more details? 175n
Tried at my dads place with z11 pro max
Resolution stays too
But Miro, i would really try a seperate z11 pro max like mentioned. Just to see - faulty box
Z Mini
1080p /50hz
Stays, with 1 hour Standby, even after i plug power cable. -
Oh yes this is possible. Austria
Request for Formuler - Market
simpliTV | TV-Streaming App - Apps on Google PlayStream TV channels as well as films, series and sports highlights live and on demand.play.google.com
SimpliTV App. The One from Google Play Store works, but the Picture Quality is blurry. Working on a Google TV Box or something.
Maybe you can put a working one into the market my friends ❤️ -
Do do have HDMI CEC activated?
Im confused now 😂
What should i test please 😂
Thanks for the effort. Probleem is not wth MOL3, AFR will change the Hz. Just happened that at home is used for general purpose with other apps than MOL3.
Anyway I will stick with something else I guess.
Again thanks for trying to help
No, i understand you.
So your box jumps back to Auto after Standby.
Even if you change to 1080p/50hz OutputIs that correct?
I really dont use formuler in general. But my whole family and friends. And i recommend formuler and MOL3 to everyone.
I have the device to test.
I will plug it into my tv, LG OLED.
Put the settings to 1080p/50hz and in the morning i will check and give you an answer.
Yes Auto is 4K/60hz.AFR on in MOL3.
Miro, i have a z mini.
What should i do?
Resolution in the Android Menu to 1080p /50 hz -
I mean, thats the problem of the app of your provider. If there is no AFR. Sorry thats really a bad app.
When the TV stream is 1080p 50hz, then my TV looks much better at 4k50hz . I guess in countries where 30/60 Hz is standaard, there will be not a problem. In in my case ( and I am sure also apply for other EU customers) when the box switch to 4k60hz, picture is stuttering. Anyway I hope is possible to fix it. I did try everything, all HDMI ports, different cabels, hard reset, soft reset, HDR off, HDMI CEC off , etc.... Will have to wait and see, I am sure is not a big deal to fix, as any other device I have tried don't show such behavior.
P.S. I agree that using My Tv online with AFR, probably is not a problem. But watching with provider's app, without AFR, then I prefer to keep the resolution I chose
I would never use a providers app 😂
You van change it at screen resolution my friend.
Turn it from "auto" to 4k 50hz.
Legend, he wrote it switches automatic back after start
Englisch only
I come back here because if the Problem with the No Sound after StandBy
My Uncle has a Samsung TV with Z11 Pro Max BTActually everything works, but now, every second day, after he turns on the TV (HDMI ARC, turns on TV / Formuler) there is no Sound at MOL3.
I also did the solution in the Formuler Remote App, where the Mute Button is located on the bottom right. I put away this button and there is no function now.
It worked for a couple of days, but now. This thing comes back every second day.If you do Volume+\- you see the samsung tv volume indicator.
But there is just no sound coming out. Only after we restart the box, its working.
Please help
Formuler adapts apps from the app store to their system. So please try it.
Please try that one from the market and come back if this problem is still here
Do you use the App from the formuler market?
Where you got the disconnects? Wireless LAN / LAN / In mytvonline?
every Z10 Device:
Optional
unterstützter USB-ATSC-Tuner :
- Hauppauge WinTV-HVR-955Q (2040:b123)
- Hauppauge WinTV-HVR-955Q (2040:b150)
- Hauppauge WinTV-dualHD (2040:026d)unterstützter USB-DVB-T-Tuner :
- Hauppauge WinTV-dualHD (2040:8265)
- Geniatech MyGica T230 Black (0572:689A)
- Geniatech OEM T230 White (0572:c68a)- Xbox One Digital TV Tuner (045E:02D5)
you see this info on the bottom of each product information page from formuler.tv
Plex from market (formuler) works incredible good
I wish MOL 3 could implement Plex User/Pass.
That would be insane addition. ❤️ -
One device (z11) where i had this, i removed the hotkey for mute
No probs after that
Try peter solution first -
Its your provider. Its blocked. Try a VPN
