Hi: How many people that have a formuler Z11 max pro run a plex client app on it?How goes it work compared to the Nvida shield pro as a plex client.I have all my media on my PC which acts as my sever.Thanks for any feedback!!![]()
Formuler Z11 pro max w/plex?
- Z11 Pro MAX
- Apps
Videoguru99 -
July 31, 2024 at 5:48 AM
Just install plex from playstore.
And then follow instructions andthere should be somewere a option to commect with pc or so.
Check google how to set it up. But if it work on a shield you say, think that it also work with a z11 pro max.
I use no plex. But have a nas.
Plex from market (formuler) works incredible good
I wish MOL 3 could implement Plex User/Pass.
That would be insane addition. ❤️ -
I've had Plex User running for more than 5 years (Z10, then Z11) with no issues.
I have issue where I have movies which are 7.1 true audio. So they don’t direct play onto z 11 pro max. Any work around?
Maby kodi?
And then passthrough on, that it plays via your soundbar? If you have.
