hi when I plug in my w3 antenna that came with my z7 it says can not find device in the wifi settings
Posts by Bobbybacala
Anyone know how to use google Assistant on the new update? I downloaded google assistant and its telling me to update it wont let me
how do we use google assistant
If i get it from Formuler then i will post here.
can sam or a admin post the alpha wallpaper on here? I would like to put it on my z8 I like it better then the purple/blue wallpaper on the z8
And when you look live tv.
And you hold the resolution button in for 5 seconds? (Under the blue button)
And you have set your "dispaly area" under settings right?
I'm talking about the g.u.i not the resolution
Or maby if you have an computer monitor with hdmi?
With a computer screen there is a button for auto adjustment for settings and or a menu where you can adjust screen settings if its not automatic.
After adjustment connect it to your tv again
Formuler said you can't switch it back
Isn't this possible in settings?
At screen setup?
I dont know the preciesly name
And there is another option in the settings for user interace. You can set it to 720p or 1080p.
Hope it helps you
Can't switch it back
please put out an option to switch it back
Funny you mentioned that. I did try 4K youtube but with the app on my TV with no problem. I see your point.
I will download the youtube app on the Z7+ and try playing 4K content that way and see how it goes.
Good idea and I will report back and let you know how it goes. Thanks for now.
I've been complaining about 4k YouTube videos freezing forever they said they will eventually fix it but I doubt it it's been going on for over 2 years
About symbols and font size under settings, this is the answer and stays like it is : The previous UI size created some readability issues due to tiny fonts. This new size improves readability for elderly, visually impaired, or otherwise.
So no option to change back on next update? I think you guys should add it let people choose I don't like the new size
Is only in Settings.
I guess many people with smaller tv want this to see better, unfortunately on big tv`s it looks really too big.
Yes exactly I have a 70 inch it's too big
yes make it an option to change the size of the u.i I dont like it big
this issue is happening to me now after latest update
could be ethernet cord as well cat 6 and 7 dont work well with formuler boxes
I can't connect to portal after latest update
Oh ok thanks sam
Which Firmware version do you have?
Any updates? Have you tried watching 4k YouTube video?
any updates from the formuler team
I got a new video showing the problem
External Content youtu.beContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy. -
I bought Formuler 8Z today, The written features on the box and the manual book shows 4K 60fps , but unfortunately, when I tried to watch 4K video on YouTube, it had a lot of pauses and doesn’t run smoothly like my previous box . I checked the display settings and the maximum resolution is 2160p 30Hz , so does that means it’s not 60fps ?
I'm having the same problem did you solve it?
Newest one for YouTube and formuler this has been going on since I had my z7
The app is called smart YouTube tv and is available on the formuler market store ! I mean not Youtube 2.0. works fine
Just installed smart YouTube same thing it freezes
Could you please share link to this version of app? Helps others
Thank you.It's the latest app from the market
I solved the problem, I have just installed the YouTube app for smart TVs on the market store, when using this app I got no freezing on 4K videos
Are you sure? The youtube app I'm using is from the formuler market
here is a video for referenceExternal Content youtu.beContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy.
anyone having this problem?
Hi
I get always this issue...sound desynchronized from lips randomly...one day correct one day bad.
Current S/W version 1.2.71
Current IPTV version 1.9.75
Please what can I do to solve that ?
They fixed it for the z8 other models maybe next update
Im getting the same problem on a Mac sub I was told in the telegram group their working on it
Im having the same problem on a Wired connection sometimes the internet will cut off screen goes black for both of my services even when I use a movie APK links won't show
Display More
My Z8 is not working very well since the last update...
Sometimes, it stop working suddenly or i can't doing anything with the remote...
I did 3 times a reset factory but still...
Anyone know how to fix the problem..?
I can't waiting for the next update....!
Does the screen go black?
happy days I hope they resolve it for those who have issues with this box
Any news on this? I'm also experiencing micro stuttering that are always present on many channels
their working on it
well it's definitely formuler issue as I tried a few boxes I own and siptv app built into tv and all are flawless
they found the problem they are working on it
You are probably refering to micro stuttering they are fixing it should come out next update
Made my account here just to post about the same issue. Kinda glad to know it's not just me.
There working on it
Hundreds different providers out in the world with different content, settings, resources and the box must work with all of them, not easy to cover all. Only the bigger one, let me say: use same standard and with this works the box fine.
How ever, the problem is always same. If user have issues like in this thread, the devs. need same line for test, to find and reproduce the issue under same condition, otherwise it is impossible to find solution. Devs. need same line as trial for test, so the reporters should contact me or 175n trough pm and proceed detailed information. Thx.
I use a Mac sub
With formuler z7+
Did you fix the problem? I'm having same issues
