Constant skipping and slight stuttering on channels
  • There desperately needs to be some standards adhered to by IPTV providers so hardware providers like Formuler don't have to guess or scramble to gather up a bunch of different streams to figure out the decode methods for each.
    Hundreds different providers out in the world with different content, settings, resources and the box must work with all of them, not easy to cover all. Only the bigger one, let me say: use same standard and with this works the box fine.
    How ever, the problem is always same. If user have issues like in this thread, the devs. need same line for test, to find and reproduce the issue under same condition, otherwise it is impossible to find solution. Devs. need same line as trial for test, so the reporters should contact me or 175n trough pm and proceed detailed information. Thx.
  • Hundreds different providers out in the world with different content, settings, resources and the box must work with all of them, not easy to cover all. Only the bigger one, let me say: use same standard and with this works the box fine.
    I use a Mac sub
    With all due respect Sam, it's far from "impossible to find solution" if other devices and apps have done it. Did amazon ask their customers for access to these streams so their firestick can decode these streams properly? How about the chinese devs of the $35 android box that also decodes these channels without issue? BuzzTV?
    Edited 2 times, last by Islander (April 2, 2019 at 12:28 PM).
