Can you please make MYTv online app for Android TV and Google tv. So I can download on tv so don't needed box.
No, there are the boxes for.
For sale.
They are great
For sale.
They are great
do you guys have a NAS, and other vpn then protonvpn or nordvpn? And can test it?
And do NAS connect at startup with the box and disconnect when the vpn is connected? Also if you splittunneling all the apps inclusive the system apps?
Can somebody with a NAS (hardwired) to the router just like me, and have another vpn provider than protonvpn and nordvpn test if the nas connect and then disconnect?
So i can find out what it is. Box or vpn.
I think already carefully the box, cause protonvpn and nordvpn disconnect nas.
I use ProtonVPN. I have also tried the split tunneling and only enabled the MyTVOnline app, same thing.
Also like you I can enable it manually, but that becomes a problem when I'm not the one using the box. Need something fool proof so I can use the NAS to store recordings.
Hence feature request, have NAS mounted shares auto-reconnect.
Thank you for your answer my friend,
So conclusion is when the NAS connect at startup and when vpn after that connect it disconnect automatic our NAS with my nordvpn and with your proton vpn. Have it on my z11 and z12.
So the temporary fix is only connect manually your nas after your vpn is connected.
But if it happens at two boxes and with 2 different vpn's...
...maby the firmware needs a firmware update.
When i remove vpn it works fine.
When i install vpn and splittunnelling serious all apps inclusive the system apps it connect also the NAS, but disconnecting after vpn is connected. But all apps are in the splittunneling???
Yes, tried the options listed above but nothing has worked
Try remove cache from mytvonline2 and make new portal with your credentials.
Maby it works then.
I am having the same issue with my Formuler Z10. I tried the same IPTV service on my old Formuler Z7 and all the channels work there. I have also tried different apps and they all work, so the issue seems to be related to the Z10 in my case.
Is there any way to fix this?
Already tried refresh from menu?
Yes,on occasion,my z12 freezes and i get message no inet connection(0)a network error error occurred.
In that case i have an exclamation mark on wifi icon,i have to reset router,because i am completely offline(YT doesnt work)
After a while my box reconnects,i also think my vpn(nord) influences the issue as before it happens,the right upper corner bars are lowered to the point of no bar filled at all.I didnt have this problem before the latest Nord vpn update.
Try protocol Nordwhisper from nordvpn.
Maby it helps henkie.
I have same problem with nordvpn.
When nordvpn is off and i restart box the nas connected itself and stays.
When i use nordvpn and restart box, nas will connect and disconnect after my vpn is connected.
So what did i do?
I used splittunneling. And i put seriously ALL the apps from the list in nordvpn inclusive systemapp to the split tunneling side. (That means no app use nord vpn anymore.
I restarted box. And nas connected.
Then vpn connected and the nas disconnected again.
Strange, because i put ALL apps from the box inclusive the systems apps to the splittunnel.
In short: i have vpn, but none app is protected by nordvpn.
And my NAS still disconnect.
So it's a box problem maby or nordvpn.
But later this day i contact nordvpn costumer service. The answers are really good and fast.
Which vpn do you use?
Temporary fix: after your vpn connected you can add the network storage manually back. And at power options you can set the box to standby.
Hi guys thanks for allowing me into the forum. My question is my IPTV subscription has no url only password and username (they won't supply URL) is there any way I can install it to my box with only these details.
Thanks A
You can't add a new portal with a url?
Is give you only option with a username and password?
Gonawaybat that provider direcly and search other one!
To remove provider block do:
Go to Settings > Storage & Reset on your Z11.
If a block is installed, you will see an option to "Check for configuration update".
Highlight the configuration line, then press the 0 (zero) button 10 times on your remote. This will perform a factory reset and remove the block.
I stay away from providers who blocks the device. So you forces to stay with them. Always buy box at a (online) store and set it up yourself.
What if you want more portal/providers? I can't.
Please follow steps, unblock your box yourself and search for free test and choose the best.
Goodday my friend
So there isn’t like a panelized version of mol3 that my provider can use which will allow users to add their portal without entering the URL?
Choose better provider. Providers who forcing you, you need to stay away.
It's your box! You decide what happen with it.
Use my steps!!
I don't help you anymore. I wrote 3 times or so what to do. You won't listen. Then my help stops from here.
Goodluck and goodday
I have a BT3 remote control and programmed this with my own TV buttons.
Question is now how do I activate the OK button working on my TV when pressing OK on the BT3 remote control.
All other functions (like sound, power) are working, but I need to know how to activate the OK working as the same as from the TV remote control.
Ok button can't be programmed.
Working only with the box!
With mytvonline3 and with play store etc.
The whole control of the box can with ok button.
Your tv can with side buttons volume bar up an down.
And button upper left corner power on and off tv.
Goodday my friend
Did you try these steps??
Thank you very much, Lucky133
There we are for. To help each other.
Good weekend my friend!
Hi guys, loving the Z12 Ultra.
The only thing that really bugs me, is there any way to organize the channels in each category in Alphabetical order?
I saw the Favorites can do this, but I want to do that, without loading everything to Favorites.
Thank you,
Mark7
Yes,
Go to a group where you want to set to alphabetical order and choose a channel.
then press OK button
Then push red aquare button
Then choose A-Z
Like i mention first, it was blocked by your provider.
Thank you so much for your kind words.
Goodday my friend Duldjie
Edit: Is Beatv a channel on youtube or do you mean beetv? Because Beetv use to many ads between watching.
The App were you looking for, see https://www.formuler-support.tv/conversation-list/
Hi folks,
Does anyone use the app Cinema HD for free vod/series? Many years ago we got Popcorn time but its down now. Does some people here know good alternatives to watch free movies/series like Cinema HD?
BeeTV 🤫
Thanks Henkie for your fast answer.
It's in the Z8 section posted, so i should be correct. And his device is mentioned in the thread name.
Try to find this please:
Go to home menu ->Settings -> Storage & Reset ->if block installed, you should see menu entry "Check for configuration update" -> Highlight the configuration line, then press 0 (Zero) -x10 times -> It will factory reset and unblock the entire device.
And let me know please
Hi everyone.
I have a Z+Neo, with not to many apps installed, just Mytvonline2, Audio Optimizer and a VPN (Surfshark).
2 days ago I was turning the VPN on and saw a message saying that a new version was available to update. When I tried to update it, there was a message saying I didn't had enough storage to update. So I did what I always do when this happened: I reset the formuler box to factory defaults in order to free some space. As soon as the factory default reset was done, I removed all the apps I don't need and installed the ones I always have with no problems.
But this time something different happened. As soon as MyTVonline2 was installed, the app opened in the connections menu and there was no "Add Portal" option. Just a "kopke API" folder as shown in the attached picture, that when selected asks me for a user and password I don't know what are. I tried so many things already (force stop mytvonline2, erase data and cache, taking out the power cable and turn it back on pressing the red button on the remote, putting on the 0227 code on the update page to the beta, nothing works).
Can someone explain to my what I have to do to solve this?
You factory reset your box.
Ok.
What's now the problem?
You can't add a new portal with credentials?
Isn't it there anymore?
Or device storage to full?
You got also such device right, can you describe the correct order?
He says he can't add portal. So i think it's a blocked device due provider.
He already factory reset his device so it’s not needed to uninstall mytvonline2 and reinstall it from market cause it’s a fresh install already due factory reset.
Nothing happens, on system info this is what i have. The vendor couldn't block my box, I already did factory default reset many times before and this never happened.
Can you find maby this?
Goodday my friend,
Im sorry, the option insn't there you mean? My bad.
Your box is blocked. I think you bought it at your provider.
Go to home menu -> system info -> if block installed, you should see menu entry "Check for configuration update"-> Highlight the configuration line, then press 0 (Zero) -x10 times -> It will factory reset and unblock the entire device.
Don't now the exactly steps.
Or something like this:
Let me/us know if it worked out for you.
Have a nice weekend.
Thank you guys for the replies but I am still clueless as to why the box itself, without VPN, can not achieve better download speed. If the port is 1000 Mbs and it is hard wired with a good cable and only a few feet away fro the modem, shouldn't it get better speeds, with or without VPN? Is there something I have to do in settings to get it to work?
Without vpn it should get the full internet service provider speed.
Only if nobody in the household use the internet for streaming or downloading.
It lowers your speed also.
A vpn slows your speed also. This is because your data will be encryped/secured on your device till the end of its destination like your iptv server provider. Due the encrytion it lowers the speed/bandwith but that's normally not so much. On the destination at your iptv provider it will encrypyed.
I have a internet service provider with 1000mbit (1 gigabit) and nordvpn fastest server can sometimes peak the 800 a 900 mbit.
So fast enough.
Goodday my friend
Hi there, I have already installed Audio Optimizer as it's the first thing I do, yet while using hardware acceleration in CloudStream most of the videos now have excellent decoding for the video part, but there is no audio playback at all. In order to get audio working you need to switch to Software Decoding which is obviously highly undesirable on 4K sources
Is there any additional codecs or optimizers that can be installed to natively handle this problem? I'm thinking maybe it's any video title that has .DV. in the title maybe?
Thanks again
I only no so far, if you have mytvonline3 open...
And soundsettings setup to passthrough in androidsettings, so it plays dolby sound.
And when i play a movie it has no sound, if the player is also set to passthrough the sound.
I need to sshutdown mytvonline3 then and then start the movie with vlc or kodi and then have sound.
I recently upgraded my internet service to 1 gig speeds hoping to make my box work better with VPN. As it stands, VPN sucks the life out of my speeds, up to 90 %. I was hoping by doubling the speed, I would get better performance. The problem is that even though I have a new modem and new speeds, nothing changed with Formuler (Z11 Max BT) I still get low speeds (200-300 mbps without VPN) and 20-30 mbps with VPN.
I never use wifi and always hard wire the box. The same thing happens with my 3 year old mini pc that also has a giga switch and hard wired.
Any ideas?
Thank you.
Nordvpn, with automatic protocol search (do app automatic)
And set it up that "p2p fastest server" is the standard.
Goodday my friend
hi,
I understand there is a method of adding a provider and keeping the url hidden. Although the provider would have to contact yourselves and make this available, please could someone contact me to run through the process and expense please.
Thanks,Josh
Goodday my friend Josh,
I know i know...
Maby he had already heard about a date for beta or official or so...
...just asking my friend![]()
I'll keep an eye on it.
refreshing manually like you described doesn't work.
hopefully the automatic 3 hrs does the trick
Read it again please my steps.
And try it again. I works also on the "manual" way.
But like i said, shouldn't be nessesary anymore when device is stanby or on.
You can checkt it also in Contentmanager and then at contentdata behind your Subscription you see while updating epg a moving icon from left to right.
Is there any news or date SAM about an expected beta or original software update.
Goodday 😀
Alright gave it a try yesterdat evening.
nothing yet yesterday, but since this morning i have the epg back.
i hope it will stay working
. Thanks
You can also do:
MytvOnline 3, menu, Contentmanager, data sync, EPG data, update EPG.
Its the same to updat only your epg, but then you do it on the manual way.
But should not nessesary anymore. You set the epg interval to 3 hours and that will do Mytvonline3 for you every 3 hours automatically.
Goodday my friend
Display MoreHi formuler team, long time fan
I have two z8 pros in the same building. One is giving issues where there is the VPN key despite having no VPN. The other box does not have this key. The problem z8 also has the exclamation point on the wifi logo despite countless toggling, restarts, blogs etc over many months.
I looked over my wifi settings.
I actually have two wifi networks. I’ve forgotten the networks countless times and they always have an exclamation 90% of the time
Despite this. YouTube does work, and mytvonline2 has worked. But the last few weeks it’s gotten worse
Youtibe for example loads 10%-60% of the homepage thumbnails and then won’t play a video until loading for a minute
MyTvOnline2 (auto launched) will spin and say waiting for network connection (3/) and time out all while waiting for the wifi (almost always showing exclamation, but connected)
I have restarted both routers many timeTHE TIME goes from 8:00 to the correct time ! Meaning it does connect ! But then is super shaky !!
The wired thing is the key when there should not be. Both networks have this. Never had a vpn.
Anyone know what else the key could mean?
I know that some providers say that on there servers run vpn for security. Can it maby be then if you connect to mytvonline2 that it then appears the key logo? Or direct at startup without starting mytvonline?
New router with builded in vpn?
Anyway, contact for sure your iptv seller and let them set your account to vpn for sure, so you can always connect.
Check in apps section in android settings for sure you didn't install a vpn by accident. Just for sure.
Maybe isp block. Try to connect to wifi 5G mobile hotspot to test.
I will let het now my friend Mevi
Like i said, mytvonline2 and channels work fine on wifi, she logged in for her father on google play. Worked too. Changed settings from provider dns to cloudfare dns. Worked too. Restarted box.
Checked everything. Google play updatet youtube and mytvonline2 started and could watch.
In short: everything worked on the wifi all apps...
except Formuler update gives that error??😂😂😂
Thanks everybody for your answer.
Will sent i lt to her.
Goodday.
inet. have not full access or update server blocked somewhere, in that case use VPN.
Reboot also the Router and Box.
It's in same country where i life.
Already private dns on cloudfare tested after that error but the same.
Also she said after setup first time she did go to Formuler update and directly that message.
Box also restarted and same error.
Will say tomorrow to her if she reboots the router. And check again. And will also let she test quad9.
She tested already with the setup the isp dns. Then cloudfare but same.
I had myself a GTV for years.
Bit can't remember if there was a Formuler market implemented? For the audio optimizer.
She made picture from app and i didn't saw it. So i don't it is on the device the market app.
Had been mentioned one before by Disco.
But every now and then the EPG isnt showing (lately 90% of the time it isnt)
So EPG information isnt showing when pressing Guide.
but EPG specific for a channel itself does work.
Are you on xtream codes?
Try mytvonline3
Menu Contentmanager
Contentsources
Edit your provider
Find update epg interval
Set to 3 hour
Click save/update.
Restart box
Just wondering if the z12 remote is larger than z11, can someone post a picture if possible?
+- 3mm longer
Thank you for your answer.
I already tried with a PC monitor, but there is no signal on it either.
I think the firmware might be completely corrupted.Could you please send me a private download link for the USB factory reset or recovery file for the Formuler Z10 (non-Pro / non-Max)?
I really need to reinstall the firmware because the box powers on (white LED) but shows no HDMI output at all.Thank you so much for your help 🙏
There is no firmware availeble for download.
Maby you can try more tv's? At a friend or neighbor or so. But if a couple devices give no image. looks it's broken. Buy new device.
Just noticed something:re-ordering providers doesnt work anymore
Does it work at your side woste?
At my side it does work.
Contentsources and hold ok on provider and then i can move them up or down.
You can control it from Home screen > Settings > Device Preferences > Display and sound > Status LED Brightness
Correct, the white led.
But he also wants to dim the red led.
Edit: only the white led you can dim.
