I'm having issues with vod sound. I think it's a codec issue as it works on a Chromecast and my cell phone.
Posts by DrUnKeN_TiGeR
I ended up resetting the box.. if I updated the rubber tuner it cashes. I just didn't update it. It's working fine now.
As of yesterday when I open mol2 it force closes. I did a hard reset till closes. Any suggestions are appreciated.
cannot have both tuner and portal both connected at at same time if you enable one the other is automatically disabled.
Nevermindi figured it out
So I connected a PS4 controller once but I have since reset the box. Now when I do it asks to pair I hot ok the light goes off on the controller and the z8 goes back to searching for Bluetooth device and it isn't in the Bluetooth list. Any ideas?
I was able to pick up a few channels with the antenna in the window, I am returning it as it gets super hot. I bid on a hauppauge we will see how that goes thinking about getting an outdoor antenna more info to come
Ok so I see it finds good signal and strength on several channels but it never adds the channel
I just wonder it it is the antenna or the receiver
Did you use a computer to test the antenna that you got no results with?
This doesn't help that the z8 isn't working correctly
Anyone else have any input? I would be very appreciative.
I took laptop back kept antenna in same spot picked up about 12 channels in laptop
Do I need a booster or not
I'm using the same antenna I used on PC and yes I was in a different room. I used the USB dongle with and without a antenna booster. I don't believe that I am getting nothing in that room be cause of the antenna placement. But I can move the laptop into the room and try it again if you would like tomorrow.
Both are 0 I do see them but they stay 0
I bought a MyGica A681 USB ATSC TV when I search I find no channels. I have tried both USB ports. I have moved the antenna. I tried on my laptop it worked fine. Any other ideas?
I see USB ATSC is now supported is that US support? And only those 2 tuners listed work?
Not that I'm aware of
Just change off porn before your leave the app
The way I read this these features are added in this update:
"This time also, we get many changes and top new features. The biggest is: Backup & Restore (no more fear from factory reset
), USB DVB-T2 tuner support, Recording Manager and much more."Is USB DVB-T2 tuner support in this updated for US users now?
For now like i know, no and to be honest i dont have current infos if there will something come for US. How ever, good point to discuss this again with Formuler. Will come back to you if i get new infos.
Can you post a link to where I can purchase this item?
Will this work in the US?
I see in posts that the USB DVB-T tuner is now supported. What one do you guys suggest? Will a cheap one work or do I need an expensive one
I figured out today you can record and watch a previously recorded show at the same time
I just have to say Sam you are the man
Other thread deleted. No multi threads with same content!
For Smartphones and Tablets it is possible to use Air Sync Remote Z, remote and mirror. There is no app for now that let Z8 work on one tv and share the content on other trough network. If some day (if !) Sat to IP comes on Z8, this could be possible but for now not.
For you would be better to use on other Smart TV some other IPTV app but the same subscription M3U URL if your account supports multi line.
Thanks I had no idea about this
Thanksi think I saw where Amazon is working hopefully netlix is coming soon
Now also zapping does not work sometimes....
What is zapping?
Nevermind I didn't realize you had to use tv remote too
That's the button I'm holding sorry I miss spoke I got the tv button programed but can't get the source button programed
I can't seem to get the source button programed. I press and hold the power button till stb flashes slowly I have tried then pressing source till it changes the source on the tv (it never does). I have tried not pushing source. Nothing happens either way. Anyone get this working? I have a Vizio TV.
Has anyone successful paired a PS3 controller for gaming?
