Channels are divided with groups so kids under kids etc.. the group name is not a channel but a short group video that repeats.. after the Z8 update now i get this message if you press ok then the tv shutdown how can this be fixed on my other Z8 without the update everything works fine.
Z8 channel list issue
nouaro -
July 24, 2019 at 6:20 PM -
Now also zapping does not work sometimes....
What are you using, m3u playlist?
No I use portal and username and password, on my other z8 i did nkt do the update it works fine
Sam you got a solution for the issue? it does not matter if i use a m3u list same issue.
I did a factory reset still same issue
Explain in more detail what this means.
Sorry this issue is solved after i reset, no only the issue with the "this channel is vod "etc is apearing..
This is not an issue. The message is intended to be shown because your provider has decided to put static VOD contents in the LIVE channel list for some unknown reason.
Because before the update and on other formuler zx and zx 5g it works, also on a z8 without the update no issue..
In mol2 its added ability to play static vod on live channels... this is what made the issue is it possible to undo that
what issue?
In mol 2 the option "ability to play static vod on live channels" is added is it possible to disable that option that issue i already explained the issue
As 175n mentioned before this is not an issue. Your channel list has VOD in the live section that's why you are getting that message.
What is zapping?
Zapping is fast channel change.
