I see in posts that the USB DVB-T tuner is now supported. What one do you guys suggest? Will a cheap one work or do I need an expensive one![]()
USB DVB-T tuner
Formuler Usb dvbt-2 stick.
Will this work in the US?
For now like i know, no and to be honest i dont have current infos if there will something come for US. How ever, good point to discuss this again with Formuler. Will come back to you if i get new infos.
Can you post a link to where I can purchase this item?
DVB-T is for most countries except: USA, Canada, Mexico, S. Korea (ATSC system)
Don't buy the USB DVB-T tuner if you live in one of the countries listed above.
USB ATSC tuner support for MOL2 is in development.
If you are patient, a future software update will bring this functionality to your box.
