Z11 Max few issues
  • 2- You need to program your Z11 remote with your sound bard remote...
    3- Same probleme here,but you can try MECOOL FILE MANAGER. try it on playstore.
    5- Go to the GEAR icon in home menu and do it manuel. Do a google search...You may find a apk file to do it or You can Active Developper MODS and LIMIT BACKGROUND PROCESS options for setting.
    Stay Tune,Return after the EPG LOAD! :smiling_face_with_sunglasses:
    Nvidia...Tivimate...good choice!
    Add 5,press homebutton twice to limit background apps:smiling_face:
  • Thank you everyone, manage to programme it and control volume etc.
    The hot keys which I also setup worked but notw don't respond to any input, single tap,double tap or long press for all three.
    The coloured buttons still work fine.
    Any suggestions?
    Any suggestions?
    Use the FORMULER REMOTE APP in market store to setup your remote.
