Hi all I’m new to formuler boxes I have just purchased a Z mini is it possible to buy an adapter to plug a LAN cable in rather than utilise the WiFi
LAN Cable Adaptor For Z Mini
- Hardware
- Z mini
Volvo3389 -
July 24, 2025 at 9:44 AM
I don't personally own a Z mini but found this info that might assist ...... While it doesn't have a built-in Ethernet port, the Z Mini does have a USB-C port. You can use a USB-C to Ethernet adapter to create a wired connection.
Yes,it is possible,please read thread "Usb adapter......"
The best adapter for now is the "Bewinner USB C to RJ 45 ethernet adapter"
Check it out on Amazon site.
I was already searching that forum threat too.
But could find it fast enough this morning.
Nevermind the exact Thread,when you do search for "Bewinner",you get all the relevant info you need
Well done my friend
ThreadCompatible USB C-type hub with PD for Z mini (Database)
Dear Community,
We open this thread to create a small database in which all the compatible USB C-type hubs with PD for Z mini are listed.
Please post the hubs you use and work well with Z mini, to inform users in the community and make their purchasing decision easier.
Please create screenshot or Photo from your Hub and upload into your posting. Small review and detailed text about the HUB would also be nice.
Thank you very much.
1.
…Hardware Z mini
SAMMarch 6, 2024 at 10:06 PM
