Nord VPN
  • My z11promax keeps dropping my NordVPN.. any suggestions, it's already on auto connect. In the US.
    Try switch e.g. to Canada,if it connects,try connect to fastest server.
    Btw Nord vpn have excellent Helpdesk,where you can create a ticket,usually answered within 24 hours:smiling_face:
  • I unfortunately tried their chat which was a disaster . I'll try their help ticket thanks.
    I actually tried 3 different servers in the US and no change.
    Do you know to what speed your internet connection drops,as for regular iptv only low speeds are needed.
    In Formuler Market there are several Apps for measuring speed available.
  • I used NordVPN for almost a year, and noticed that the connection would stop randomly at times causing buffering or stream to stop until I manually re connected. Have switched to express vpn since and no such issues
    Okay, in my country no problems with it. I use standard p2p connection to my country or fastest country sometimes and my own dns setup with nordvpn. No problems here.
    My subscription ends at 2026 somewhere. Maby im going to switch also one time just for testing..😃
    Wanna test expressvpn and vpnshark.
  • Finally got it working. Had to completely UNINSTALL NORD then REINSTALL.. Now its connecting like it should. May have been a glitch somewhere but finally got it going.... thanks for all your help.
    On another not I have ExpressVPN for 2 years, about 6 years ago and had nothing but problems, that's why I switched to Nord..No problems upto now, but got it fixed.
    Thanks again for all your help..:smiling_face::smiling_face::smiling_face:
    Well done my friend.
    No problem.
    Goodday
