How Can I Remove These 2 Lines From My Formular Screen?
- Z11 Pro MAX-BT1
- Apps
nejdetcan -
August 30, 2025 at 4:15 AM -
You can't my friend
You can't my friend
Thank you for your answer. But this is nonsense; it makes no sense. I've identified many bugs in Formuler, and you might not even be aware of them. The developers of Formuler wrote them while drunk. I want to break the Formuler device, but I paid a lot of money and can't break it.
Are you sure you are not drunk yourself?
Alhamdulillah I am a Muslim and I have never consumed alcohol in my life.
You dont know what your missing,but i respect your religion
Maybe you should be less "temperamental" in your posts,as you seem to get easily frustrated,over minor issues
I'm normally a very calm, polite gentleman.
I sold my Nvidia Shield 4K TV Box for a bargain price to buy the Formuler Z11 Pro Max.
Yes, the Z11 Pro Max is generally a good device, but it has many bugs and software glitches.
I've identified 13 bugs in the Z11 Pro Max BT1 Edition. These bugs aren't even present in the $35 Next TV Box.
If we can't even remove even two simple tabs from the device screen, we need to think carefully. The situation is dire.
What was I supposed to do? Congratulate the Formuler staff, saying, "Your device is full of bugs, you've done a great job."
The biggest bug on this device is the accessibility services disconnection bug. Because of this, I can't use four important apps.
I posted on this forum and sent five emails to Formuler staff in three different countries, and I haven't even received a response.
Mr. "SAM" on this forum said that our authorized teams would investigate the issue and get back to you. It's been 9 days, and I haven't received a response yet.
THEY CORRECT THIS AND SIMILAR ERRORS WITH SOFTWARE UPDATE, BUT THEY ARE NOT INTERESTED.
Thinking I could fix the accessibility bug, I've reset my Formuler device to factory settings eight times.
I've done a hard reset once.
I've tried all versions of the Accessibility Suite numerous times, but I haven't found a solution.
Formuler officials aren't offering a solution either.
I'm not a beginner or a mediocre user. I'm a professional. I've been working in technology for 40 years.
Now, isn't it normal for me to get a little angry and frustrated?
I'm not an angel. I'm a friend. I'm human.
Damn bro, you can side load any app you want technically just install downloader and take it from there.
Regarding the launcher screen if you don’t like use the apps screen instead as it will show all apps and no side bars.
Tbh I don’t care about the launcher screen more that mytvonline3 works which it does and apps play which they do.
The formuler is an IPTV first box so maybe what you need is something else? -
The formuler is an IPTV first box so maybe what you need is something else?Thank you for your message, but using the apps screen is a complete nonsense. You should call the Formuler team to fix their ridiculous operating system. No other TV box has this much nonsense. I've identified 13 bugs in the Formuler TV Box. Don't the Formuler team know about these? But they don't care.
Seems you are here only to blame, you should sale your Z11 because you think everything is wrong and buy again your lovely Nvidia Box .
Since you didn`t read yet the forum rules and ignore them , post other Brands and only blame about everything what is on this box , is this thread closed.
Formuler launched this launcher and there will be no changes that you expect.
Thread closed!
