In Tivimate EPG is displayed but not in mytvOnline3.
Why is this?
I have updated EPG in mytvOnline3 but no EPG is displayed.
EPG is not displayed
- Z11 Pro MAX
- MYTVOnline3
Akita -
September 1, 2025 at 8:42 AM
same problem
Also have the same issue on Z11 with mytol3
No information in EPG guide
Any fixes ?
PostRE: Guides Are All "No Information" (Z11)
First, a brief description for better understanding, and then what can be done to ensure that the EPG data is displayed correctly.
As we all already know, using the Alternative EPG resolves the issue of No Information in the Stalker Protocol. However, here it's much easier with the Registered MAC Address and a simple URL.
With XC API, it's a bit different. Here, you either receive the XC Api url directly from the provider or extract it from an already received M3U URL. It's always crucial to use…
SAMMarch 16, 2024 at 5:33 PM -
Sent a question to the supplier.
Got this response:
"Hi! I didn't really understand what you mean, what port number are you referring to?" -
Because he do not use the port no in his url and btw. he don`t need to use it if he don`t want. It works also without.
Then the question remains why the EPG is displayed in Tivimate but not mytvOnlin3?
Apparently there must be some setting that I have missed?
