Premium Service activated in MYTVOnline+ but still ads on the top of the homescreen. Are the ads removed when I install my Formula Z12 Ultra with MYTVOnline3 ?
  • Dear all/support,
    Tomorrow I'll receive my Formula Z12 Ultra with MYTVOnline3 for my TV.
    On our iOS devices I like to use MYTVOnline+.
    - I activated the premium option but still there are formuler ads on the top of the homescreen. How can these be disabled? I already bought a Z12 Ultra.
    - Are the ads on disabled on MYTVOnline+ when I install my Z12 Ultra with MYTVOnline3 ?
    - I asume our favourites (Live/VOD/Serie) are shared between our iOS (MYTVOnline+) devices and our new Z12 Ultra (MYTVOnline3)?
    Thanks and best regards
  • Unfortunately,i dont think your favorites can be shared between mytvonline+ and mol3 on your z 12 ultra,because it has no backup&restore function,and you can only backup&restore on the same box.
    Please read the thread "How to use backup and restore function?"
  • Dear henkie , thanks for your quick reply.
    That would be a big minus then. I bought the z12 ultra to have a seameless IPTV solution between my iOS devices and my TV.
    I cannot seems find the formum thread ""How to use backup and restore function?" when I use the search function? Maybe you have a link.
    Do you possibly also have some knowledge on my first 2 questions?
    Muchios gracios henkie, I really appreciate all the help.
  • On phone or tablet do you have with MyTVOnline+ sort of ads at the top.
    On your Z12 you have no add cause its a paid box.
    And Formuler is smart enough to don't put ads in there app on there boxes. Otherwise they loose costumers.
    I dont know about your first two questions,i guess its up to Formuler company.
    About you second question,there is a way to upload the thread,ijust dont know how to do it,maybe F_Peter or SAM do?
    Goodday my friend,,
    On phone or tablet: is backup function in right corner. Cogwheel and then you find in the middle somewhere backup and restore.
    On your box:
    Put usb in your box.
    Start mytvonline3
    Open menu (button with 3 stripes)
    Settings
    And then almost on bottom you find options for backup and restore.
    Favorites on your phone or tablet are not sync on you box.
    Edited 2 times, last by Lucky13 (October 1, 2025 at 3:36 PM).
  • Phone or tablet not in synch with box as far as Favorites etc .
    backup &restore not possible between different devices,so not possible between z11 and z12 ultra ( Balkanboy):winking_face:
    phone/tablet are different devices from z 12 ultra box,so crossover of Fav.not possible.
  • OK Lucky13 and henkie , thanks so far for all the help, still some question (which are crucial form me to decide to keep my Z12Ultra or not). Hope you can help me out.
    We have 3 TV's and multiple iOS devices.
    1. iOS devices with the MYTVOnline+ app doesn't sync: (watched) history, favorites and groups (which LIVE / VOD / SERIE to show) with the Android OTT devices of formuler (MYTVOnline3). Question A: do the iOS devices automatically sync or has each device separate (watched) history, favorites and groups (which LIVE / VOD / SERIE to show) ?
    2. Currently testing a Z12Ultra (with the latest version of MYTVOnline3) on 1 TV.
      Question B: when buying more Z12Ultra's for the other TV's would they automatically sync: (watched) history, favorites and groups (which LIVE / VOD / SERIE to show) ?
      Question C: when buying other Android OTT devices of formuler (MYTVOnline3) for my TV's, would these other devices automatically sync: (watched) history, favorites and groups (which LIVE / VOD / SERIE to show) ?
    If nothing is synced automaticallyand every device is treated as a separate device (or I have to export - import manually each time everything) I'll return the Z12Ultra, because my wife and kids will become nuts I think :winking_face:
    1: i dont know, but i think i won't sync no. Cause every device is used apart.
    2: if you take account with more lines. It wont sync.
    You Setup one z12 mytvonline3. You make backup of mol3 with usb via mytvonline3.
    And that can you import on other z12. It import the settings, portals. Not sure if it import the favorite channels. But i thought it do.
    3: i have a z11. Backup mytvonline3 with usb.
    But when i imported it on my z12 it gave a warning that it was not done.
    Maby i had bad luck or maby it works at other person.
    But tried 2 usb backups so.
    So far i know if you make backup with mol3 its backing up portals and settings.
    I dont know for sure if it backups watched movies.
    Favorite channels i know almost dor sure.
    But wait for other user who can answer it for sure my friend.
    Edited once, last by Lucky13 (October 2, 2025 at 7:13 PM).
  • This can only be answered by SAM:smiling_face:
