Hello friends. Does anyone know why it does not have audio channels RTP1 and RTP2 of the operator NOS in portugal?
And if you organize a list, the other is disorganized. Why?
hug
Audio problem
- Miscellaneous
- S-Turbo
aftas -
February 4, 2018 at 1:01 PM -
Hello neighbor
test with yellow button and select audio -
Thanks, but it does not work.
could you please describe the problem detailed. RTP1 and 2 on DVB or Mytvonline? What do you mean with other disorganised list?
At beginning (after first Install) you get the message for install missing Audio codec (needed for some channels), done this?
The Audio PID`s from your channels are 4098 | por / 4099 | por and for rtp2 4106, this should be possible to chose trough yellow button like poli already written.
When you go to rtp1 and rtp2, press info button and tell us what stays behind : A/V (xxx/xxxxx) -
Hi, Sam.
The information is: A.V. (Unknown / MPEG2)
and these channels are in DVB.
I already installed the audio codecs.
The yellow button solution does not work. It does not hurt, it's just two channels.
It does not work in NOS, but it works in MEO, just change operator.
Greetings. -
Just curios now. What have DVB -Sat with MEO and NOS? MEO and NOS are Mobile Internet in Portugal, right?
And not only. Cable and satellite TV and telecommunications and internet.
Thx, good to know. With operator change is your problem now solved, right?
Hi
Are these s mini and z7+ capable to decode or play TRUEHD, DTS etc. on movies? on MYTVOnline app
