How do you uninstall Google assistant? I want it gone! I thought you can have a googleless formuler box, what happened? If it can't be removed I'm done with formuler.
Google assistant
- Z11 Pro MAX-BT1
- MYTVOnline3
Dwell -
February 3, 2026 at 1:04 PM -
Hello! If you don't need it just don't use the assistant button. Maybe SAM or someone else knows how to uninstall. I never came along the google assistant while using the box.
Wait till you update firmware. All sorts of Google stuff. How much did formuler get for selling everyone out to google? Found Google playstore reinstalled, now you can't uninstall that app.
It is system app, don`t understand why such hate on GPlay and assistant? Assistant is also important for Formuler BT Remotes. Btw. This Box use AOSP and that is also from Google.
If you don`t need G-play deinstall from home menu -> Holding OK button longer on GPlay icon and delete. If this is not enough and you don`t want any notifications, go to apps-> system apps and turn off the notifications or other permissions, there are few of them.
Really? Are you a bot? You have no idea why the hate on google? Your instructions didn't work on uninstalling play. How do I downgrade firmware? Don't say it can't be done. After firmware update Google turned on my location!!! There is some hate there cause nothing had permission to turn that on.
There are no bot`s on forum!
Nope it can`t be done, stays in each update thread in red!
QuoteWARNING:
Software cannot be rolled back after installation. -
ASOP os is a separate entity from Google. Yea they helped develop it but you don't need Google malware to run it.
"There are no bot`s on forum!"
Every forum today have bots in them. They have evolved from Ai and are hard to spot today.
"Software cannot be rolled back after installation"
They said the same about apple products.
You have definitely aan other problem than Google, android or Appel. Do you own a smartphone? Beware you aren't spied.
I wish you a nice evening 🙂
You can uninstall it with the app "adb manager" from playstore
Give it the right rights and enable by press 10 times on buildnumber in android settings. And enable usb-debugging and search for that app in adb manager and uninstall it by red button.
Read carefully the steps after opening it.
I have everything turned off google, all force quit all permissions off. Hey Sam tell Belgiumuser it doesn't matter if you turn everything google off. Guess I'll look at netguard app again
Thanks lucky. I have used that app before for firesticks. Forgot about that app. Need to get to the hidden files as well. Id rather sideload the app then go thru playstore. Thanks again, I'll play with it when I have time.
Hey Dwell tell him directly, he have eyes and can read, he doesn`t need some bot to tell this twice!!
Even if the help that was offered to you did not produce the desired result on your side, we tried to help you. All you got was hostility and unproductive comments. With this in mind, this BOT (ME) closes this thread.
A little kindness shouldn't be too much to ask for, especially when you ask for help.
