Hello...bit of a newbie question, but I have my Formuler GTV box set to 1080P/50Hz (UK) for TV shows, sport etc with frame matching enabled. When watching movies on VOD, do I need to manually change this to 1080P/24Hz as I believe most movies are shot at 24Hz ?
TIA
Framerate on GTV box for movies
- MYTVOnline2
- GTV
CurlyBoy88 -
May 4, 2026 at 10:12 AM
You can leave activated AFR for Live TV to have 50HZ and deactivate AFR for VOD and Series, then you have what you want.
Ahh...ok. I'll try that. Thanks for the reply.
I disabled all the AFR settings on the box and played some VOD movies and the info button on my TV says it's still receiving a 50Hz signal. The info button on the box says the movies framerate are 23.976 (24Hz) It's not a huge deal to change to framerate on the box to 1080P/24 when watching VOD films but I thought the whole idea of frame matching is that it would do this automatically. Very strange.
I have since changed the media player from VLC to default and movies are now showing a framerate of 24Hz as they should without the need to change any settings. Thanks.
Standard movie player is very good!
