Timeshifth auto/man
  • I’m using a Formuler Z11 Pro Max BT1.
    All firmware updates are installed, and I’m currently running the beta version.
    In MyTVOnline3, Timeshift is enabled and working correctly. However, I have to manually activate Timeshift every time I start a channel or switch channels. When changing channels, I’m forced to disable Timeshift first, otherwise channel switching is blocked.
    I’ve seen references indicating that Timeshift can be set to activate automatically, but I cannot find this option anywhere. When I enable Timeshift in MyTVOnline3, I only get a simple ON/OFF toggle — no “Automatic” or “Manual” mode is available.
    Is there a way to enable automatic Timeshift on the Z11 Pro Max, or is this feature restricted by the portal/provider configuration?
    Any help would be appreciated.
    Make an backup of mytvonline3 with usb stick via mytvonline3 menu.
    Delete/uninstall mytvonline3
    Reboot device
    Install mytvonline3 via market app
    Import via usb your backup.
    If problem still exist, uninstall mytvonline3 without making a backup.
    Reboot device and install via Market app again.
    Don't install beta (if available)
    If then still exist, then i think you need to do factory reset.
