mytvonline3 stops working when you choose to download VODs or tv series. every time I go to the VOD menu and try to choose a group, mytvonline3 crashes and the box returns to the Formuler Z11 home page. I specify that the connection method is with MAC address and that the live tv works well, factory reset done and other resets like mytivonline3 app reinstalled , no fix find the problem only occurs when you want to choose a movie or a tv series VOD. anyone have a solution?
MyTV online 3 crashing VOD
- Z11 Pro MAX
- MYTVOnline3
dlpp0004 -
May 20, 2026 at 3:59 AM
The devs are already aware of this issue.
I will update you once the fix or workaround is available.
Thank you
Thank you, I was here to report the same thing with units here in Canada
Is this a new thing? As mine is restarting mytv3 every time I try to open VOD or tv series. Just started doing this today.
My TV Online 3 crashes and restarts when I try to access the TV Series or VOD, just started to do this around 8 pm (eastern) on Tuesday evening live TV works fine.
These are all the same issue by the sounds of it, yes
Having the same problem. Would like to get notification when it's resolved please
The same problem here . It happened again a few weeks ago
I have this exact same issue since yesterday, and it drives me crazy. First only at series, now also having this happens with vod also. Everytime I go in series or vod mytvonline3 crashes. I made a total factory reset of the box, installed everything new again from the bottom, but nothing helps. Please help !!!!!!!!!!! Only LiveTV is working….
Any update F_Peter
A reboot issue affecting VOD/Series on MOL3 and MOL4 was caused by TMDB.
TMDB has already fixed the issue, but the changes are still being applied.
Workaround:
MOL3: Disable "Metadata API" in Player Options to restore functionality.
MOL4: TMDB has been temporarily disabled, so the issue should be resolved. However, the Home screen banners may appear empty.Affected users please try the workaround.
Working well
Made the change MOL3: Disable "Metadata API" in Player Options to restore functionality.
And it appears to have fixed the problem for me, I am not noticing any loss of functionality so far.
As above: MOL3: Disable "Metadata API" in Player Options to restore functionality.
Problem solved
working now thanks Sam.
Mine is already disabled, still VODsame issue
Delete MOL3 cache and restart the box.
I’ve been having a problem with my Formuler Z12 Ultra since today. When I open the MyTVOnline3 app and go to Movies or Series, like in the video, the app crashes and restarts itself. Because of this, I can’t watch any movies or series.
I’ve already cleared the app data and cache, and also cleared the cache on the device itself. Nothing seems to help. I’ve restarted the device, turned it off completely, and even unplugged the power, but nothing works.
Does anyone have a solution?
Secure File Sharing - FilemailShare files of any size, any format, any type, securelyapp.filemail.com -
PostRE: MyTV online 3 crashing VOD
Workaround:
SAMMay 20, 2026 at 1:22 PM -
Problem solved
Thank you disable meta data Api works by the formuler z12. Thank you
I just came on here to post the same issue. Mine started yesterday on just a few VOD movies and series is not working at all. Just keeps rebooting. Any updates yet on resolution?
Please read older postings, workaround was posted.
same problem i was disable meta dados api and works fine
same with me
It happens in mytvonline + on my tablet and there is no "Metadata API" anywhere to disable.
Any workaround for that?
Should've checked here before doing a factory reset lol....I will try this fix.
Same here Tried factory setting but does not work. Not working propperly is an isue that returns every 6 month
Switching off metadata API worked perfectly for me, thanks for posting the workaround.
Before posting please actually read the thread, the workaround has already been described above, it's very quick
Workaround did the trick!
Workaround:
Working well….but please keep us updated about
It should be working fine now. Please try to enable the metadata api, and check again.
Had the same experience yesterday. All is working again fine now. Thanks! 👍
Thanks..... work round worked for me and I have just switched metadata API back on and all seems good
Thanks all for the quick fix
On the Z11 Pro Max i Disabled the Metadata api, seems to be working and not crashing/restarting in vod, but the info on any tv series episodes no longer shows what the episodes are about ? whats the good of disabling something if it creates other issues ? According to Sams post , this issue was fixed, so why is it not working properly with the Metadata Api "On" ?? i have installed latest Hotfix also and still the same. Anyone have another workaround ?
