MYTVOnline 4 v14.1.0 BETA 2 for Z12 released
  • What kind of update is this? The box is constantly lagging; it feels like a €20 Temu box now. Why isn't there an update to Android 14? Everyone knows Android 12 sucks for TV boxes—the devs are doing a terrible job here over 2 moth for a second beta reales and than this Garbage sry don't sell boxes with this firmware
    If you think about android 12 isn't good why buy a Formuler Z12. And by the way out is clearly notification that the beta update is for test only and not for 24 hours use because it have bug's. Do you better haven't installed the bleta upgrade!
    Have a nice evening!
    Android 12 is fine.
    Android 14 isn't nessesary.
    I advice for you: do a factory reset.
    Some boxes need a factory reset after an update.
    Goodday
  • So is developer options being disabled while mol4 is running in the background going to be a permanent issue, or is this temporary. There are a few settings I like to change. Also being able to use USB debugging for ATV tools, TDUK apps no longer work if we can’t use USB debugging. Really hoping this is not permanent and wish it would have been mentioned in the beta release notes.
  • During about ten times over the day i tried to install the beta2 update,each time with the same result,after home>SW update >press1339 nothing happens,no red block on the right lower side,simply NOTHING,anyone else having the same issue?
    In android settings, go to apps, find "formuler update", and clear data?
    Then reboot device.
    Try again?
    P.s: red button isn't in Z12. After pressing 1339 a new page is coming up with a beta logo in upper right corner.
  • Funny, many eople complain about the newer versions of Android not working as well. You can't please everybody, I feel sorry for the developers. From what I can tell MOL4 is working fine
    What “newer version of android” this is a beta software update an not and android or firmware update.
  • In android settings, go to apps, find "formuler update", and clear data?
    Then reboot device.
    Try again?
    Unfortunately,did not work:frowning_face:
  • I guess i will await Official update,with all the sports going on and coming up.
