Hello guys,
Looking for some advice need a external ssd and think best to go with samsung t7 are these any good?
Also as using with timeshift etc what format and how best to do this?
khan
Hello guys,
khan
Yes, they are good. Use Ntfs.
cool what about something like the SanDisk Extreme V2 500GB USB-C Portable External SSD
Sure, each ssd, even the cheapest is for such box fast and good enough.
As previously mentioned that NTFS formatted by Rufus was the way to go. I was unable to get my Sandisk Portable SSD to work with Time shift when I formatted with NTFS. I then tried formatting SSD with Fat32 and it works on my Z12 for storage for Backups and Time shift. Just wanted to mention that in case others can't get their storage to work with Time shift
Thanks for that will help me and others for sure!
I take it formatting is done via windows pc
Thank you for your assistance
Yes, Windows PC (laptop) using Rufus Formating software using the parameters set out by Formuler (except Fat32 instead of NTFS). I only use this SSD for Timeshift and Backups. On the Z12 I have Recordings set to store on the internal storage. All works well now.
Thanks for your assistance, waiting for my t7 to arrive will be back once here.
