How can I re-number/organize channels so they are in the order I want?
Thanks!
Thanks!
Thanks!
You'll need to make a favourite group.
I have that of, course…
Just can’t remember how to rearrange/renumber the channels after creating the favorites group
If you press long ok button , you will see (up/down arrow) so that you can move, as well as group list you can change the order.
Is that right?
Let me know my friend. Goodluck and goodday.
press fav group using remote then info button on remote
Not on a Z8 right?
Ahh apologies, long time since I had a Z8 lol
I’m actually using a CC, sorry.
No luck so far trying different key combinations
For me too.
Had almost all formulers, since 2015 or so? except the satellite F serie.
But back on topic.
I see older posts with different instructions, likely for different devices, but none work…
Oh in that case.
You posted in the wrong Formuler box topic.
But can happen, my friend. No worries.
The steps should be:
Rearrange and sort your favorite channels manually with this straightforward method:
See also: https://support.formuler.tv/kb/article/122…tor-mytvonline/
