Doesn’t connect automatically to WiFi
  • My Z11 always connected automatically to my WiFi network when powered on. 3 days ago my Starlink router got stuck in a reboot. I had to do a factory reset on it and then connect the Z11 back to my WiFi network.
    But now, whenever I turn off my Z11 (power off) and restart it, it won’t connect automatically to my WiFi network. I disconnected and reconnected the WiFi several times. Every other device in my household does work as expected, only Z11 doesn’t. Does anyone have an idea what else I could do? Thank you in advance!
    Try completely turning power off from formuler (unplug from socket for a few minutes) and then turn of router (unplug from wall for a few minutes) reconnect router and reboot once fully rebooted then plug in formuler and start up.
  • Good job my friend, well done.
    Thanks Lucky13
    Still dealing with the following issues ever since I bought Z11 in April 2025
    • z11 will not turn on and record programmed recording when in standby mode. Works flawlessly when in power off mode
    • Z11 will not shut off after programmed recording is finished (recording is programmed for every day 6 to 7 pm)
    • Z11 will automatically shut off every day somewhere between 11.45 pm and 12.30 am. I assume it is the delayed shut off from the recording
    • When we have a power outage during the day (rural Alberta), Z11 will turn on for recording at programmed time, but then displaying an emergency message and shut off after 10 sec countdown. If you don’t pay attention, you don’t get the recording. That’s annoying.
    • I brought up these issues (not the last one) here several times but never got a workable fix. SAM ‘s advice to switch from standby to power off mode at least gave me the desired recording. So, I am grateful for that.
    • Have a great day!
