Hello, Since June 28th, expressvpn no longer works properly with mytvonline 3 and 4, each time the channel is changed there is a latency of 5 to 10 seconds, and when you play a video in VOD, the connection crashes at the exit. I tried with another IPTV player (tivimate) and it works well... There is a problem between expressvpn and mytvonline 3 and 4...
- Apps
- Z12 Ultra
bart85 -
July 13, 2026 at 7:00 AM
I advice to try nordvpn my friend.
But do you install latest version from expressvpn from google playstore on your Z12?
You say it's since June 28.
Did expressvpn get an update some days before? i can't find a direct download for latest version of expressvpn.
Maby you can contact them first? Don't say you use iptv😉
The official version yet is 12.70 version and a beta from july is 12.71 version.
Go to there website, login and search for Androidtv version.
ExpressVPN works for me, version 12.69.0. A little delay when changing channels, but that's always been the case with VPNs.
svejoh
Display More
Hello, Yes, the issue occurred after the June 28 update of expressVpn. I reverted to an earlier version but it didn't fix the problem. I contacted expressVpn and they couldn't do anything either, yet the customer service is responsive and listening, I was frank with them and I told them the problem clearly, anyway expressVpn is pre-installed on formuler Z12, so there is a commercial agreement, and no one has any illusions about the use of their boxes... The problem is that the problem arises only with mytvonline 3 and 4, with other players like Tivimate, I am not a problem, so there is clearly a conflict between mytvonline and expressVpn... I tried with other vpns and no problem... And I can't change my vpn, I took a 26-month subscription for 80€, the price was interesting... The solution for the moment is that I don't use mytvonline anymore but Tivimate which works well.
Isn't it possible to create a config file in the ExpressVPN portal? Then you could install the official WireGuard app from the Play Store and add that config file. That might work better than using the official app. It's just an idea; I don't have any experience with ExpressVPN myself.
Airvpn works also great more settings for advanced users. With "Eddie" app works smoothly with Mytv online 4/ 3.
svejoh
Which server do you use ?, thank you
Hello, Since June 28th, expressvpn no longer works.
Please install this version from july 13. Newest version came out today.
ExpressVPN_v12.71.0(12710040).apk1 file sent via WeTransfer, the simplest way to send your files around the worldwe.tlVersion: 12.71
Goodday my friend,
and let us know if it worked out for you.
And try also other servers from your country and or country next to you like svejoh said.
Display More
https://we.tl/t-5abWxs3hDTwLq30e
Version: 12.71
Goodday my friend,
I installed the latest version of expressVpn and it didn't change anything, I tried other servers and nothing helped... I tried with another IPTV provider to be sure and it's the same thing. I have no problem with other vpns, it comes from expressVpn for sure, 3 new versions since June 28th, there is a problem with expressVpn...
