Formuler z12 ultra
  • Where can i buy a Formuler Z12 ultra for zNew Zealand thats not geoblocked and ready to use here
    Hello my friend,
    For you is the best to buy on Australia website and or European website.
    But!!! They are geoblocked.
    The Australian website i will search for you and post later.
    How to workaround the geoblock? (One time only)
    1 buy box in Europe (amazon/ebay) or so and or Australian website.
    2 install a vpn on your phone and connect to a country where you bought the box. If it's a European box, you have more choices for countries to connect with vpn. I advice Nordvpn. Install it on phone and connect to a European country if you bought box there, and or to Australia if you bought box there.
    3: if you bought an European box as example, connect with your phone to an European country like Belgium, Netherlands, Germany Portugal or so.
    4: Make a wifi hotspot on your phone only when connected to a vpn server in Europe!
    5: Now plug in your box and power your box on BUT DON'T INSERT AN ETHERNET CABLE!!
    6: If box is booted to homescreen, go to settings, wifi and connect to your mobile wifi hotspot. (Which is connected to an European country with vpn)
    7: Open software update and install latest software/firmware and Mytvonline. The box will reboot after succes.
    8: The box connects automatically again with your mobile phone with vpn connection on after the reboot.
    Setup Mytvonline and test some channels.
    9: Reboot device (hold on/off button on remote for 2 seconds) and choose reboot and test again Mytvonline via wifi your mobile hotspot with vpn still on ofcourse.
    10. If Mytvonline works fine after 2nd reboot (for sure) , then you can shutdown box and use you own ethernet and or home wifi. Cause due setting up box with vpn to different country you activate box (in Europe) in this case and now the block wouldn't be show up.
    After 2nd reboot you should use box everywhere in the world.
    Goodluck my friend😃
    Ask seller for sure it's European box and or Australian box. I advice European box, cause some vpn's doesn't have servers in Australia.
    Nordvpn has Australian servers! (Nr 1 vpn)
    Oh and i don't know about how your power sockets look like in new sealand. But highly possible you need to buy a power sockey for a european to New Zealand.
    But you already know that in think.
    Edit: i found on internet you need an power socker from type C or F to type I.
    Edited 3 times, last by Lucky13 (July 14, 2026 at 11:40 AM).
