Hey Guys,
I use Vaders and find that several channels (mainly in the US category) won’t tune in even though they will work with ProgTV on the same box.
Anyone else having the same issue?
Seems like it might be a decoder/player issue
Thanks!
Hey Guys,
Thanks!
Same issue had it for a couple of weeks since vaders had some problems with servers.
Thanks man, so still an issue for you? Also, have you let the Vaders peeps know?
Was still an issue up until tonight. I thought it was isp related as it previously worked flawlessly. I did let vaders know but there support is non existent now as I subscribed with them direct and now they only deal with resellers.
Cool, thanks. I escalated through my reseller.... maybe the Formuler peeps can chat with then for us.
This is not just Vaders.
As they are down yet again, I am using my backup cheap-o service and the function is similar.
Seems to happen more with the regionals, I think but could be wrong about that. Anyway, select the channel from the guide and the stream either does not change while putting the tv icon on the newly selected channel or spins on a black screen for a bit and then returns to the previous channel. However, if you use the channel up/down button and allow that new stream to come up, then return to the originally selected channel with the appropriate up/down button, you will get where you wanted to be.
I am using IPTV Express. Contant buffering problem.Any help.
Hard wired with Cat 7 ethernet. 60 abs
Thank you .
Thank you .
Yeah, contact IPTV Express.
This is a box related forum, so only gonna get answers related to the hardware of box, or software updates for formuler, any iptv stuff always best check user end, troubleshoot then contact your supplier.
