Which Chipset, CPU and GPU is used in the Z7+
  • Hi All,
    I wanted to ask which Chipset, CPU and GPU is being used in the Formuler Z7+?
    At most I am able to find is that the Chipset might be a Hisilicon-Hi3798MV200 1.6 Ghz/2.0 Ghz is this all correct? Please correct me if it is a Hi3798CV200 instead.
    The CPU as indicated is a Arm Cortex-A53 up to 2.0 Ghz. Is this also correct?
    The GPU finding it hard to find .. either a Penta .. or just Mali. Can you please let me know the exact one?
    Also currently I have not used Netflix wanting to know if it also supports 4K at 2160 @ 60FPS or 60Hfz like YouTube. Or is it different on what Netflix supports with the Z7+?
    People are giving out mixed information which isn't correct and want to be 100% accurate when I reply.
    Again a big Thanks in advance to the Formuler Team.
    Edited 2 times, last by NewToIPTV (May 11, 2018 at 5:16 AM).
  • Hi,
    1.
    Chipset: Hi3798MV200
    CPU: Quad-core ARM Cortex A53
    GPU: Asked Formuler, because i`m not sure. Will let you know.
    2.
    In the Box is L3 implemented for Netflix (license free). L1 (license) is necessary for HD and 4K Netflix but also depends from abo you have there. We are for Netflix small player and need first to sale 1Mill. Boxes to get the license. :winking_face:
    3.
    Youtube with 2160p and 60HZ only with latest Youtube 2.x App.
  • Amazing! Thank You so much SAM and 175n you both always hook me up with great replies.
    As far as I can see 1 Million will be happening can't wait specially if ever marketed would love to be a part of it. Formuler is the best and please keep it this way. Even if most people don't know about it. Have research a bunch and with everything out so far it is a few steps in front of all other devices specially due to MyTvOnline having start up option plus a few other features other devices don't have.
    Please do let me know about the GPU when you get the chance, Thanks a bunch Formuler Team!
  • this is great to know the spec of this 7+ box, may i ask what is the spec of the Z nano as if i am correct is it the hi3798c v200 as if so.. wow im impressed this nano box uses a great cpu "raw power" for a cheaper box although not sure if the gpu is the mp2 or mp4 of the T720
