Which VPN Client (NordVPN) schould i download for the Formuler Z7+.
The "Android" or the "Android TV" one?
https://nordvpn.com/de/download/
Thanks in advice
Choclo
Thanks in advice
Choclo
Android
ps you might need to use your mouse pointer button on the remote to use the app properly b
thx Sir!
I also have Formuler Z7+. What are the advantages of downloading VPV (android ). Sorry for my ignorance . Please bear with me. Thank you.
Some IPTV suppliers are having issues when EPL live football is on especially in the UK I believe Vader have recommend using VPN to overcome this.
I had the same problem with Footie...
Now using VPN all fine now...
Hope this help also...
Works for me fine as well. Downloaded the app, registered and works as a train.
I got NORD VPN as I'm in the UK. Assuming I simply download the android app, select country and away I go? ANy specific country that works well for IPTV?
basically yeah. The closer to your location the better
On 200meg download with VM and regularly manage to get this speed and slightly more on occasions on my laptop using wifi..... when connected to Nord VPN on laptop I get around 80-85meg, however on my formuler z7+ ethernet connected and not connected to Nord VPN I get around 85meg and only 20meg max when connected to Nord VPN no matter what country location I choose, surely I should be able to get more than 20meg max? ..... Anyone suggest the reason why?
Have you checked router settings? I would first look there to see if something is limiting your speeds.
Sorry I don’t have VM so can’t help you with exactly which settings to check.
After that, I would go to Nord VPN and enable/disable settings to see if anything helps.
For your particular hardware, try changing setting to static ip.
Tried and checked all this but still the same unfortunately.
