Z7+
  • Greetings,
    Did a wifi test on the z7+ was only getting 75mbps download and my z7+ is very close to my router and then I did another test with another android box on wifi and was getting 175mbps download I wonder if I get the the Dreamlink W3 1200 Mbps high speed that’s dual band will improve my download speed ? the speed wired is just has fast has if I was on wifi only getting like 80 Mbps download wired that’s ridiculous with a robust device like that if I get the W3. USB 1200mbps I can connect it to my 5G and see if that works out they should have put a giga Ethernet Card in the z7+ Don’t get me wrong I like the z7+ and my IPTV Launcher keeps stopping when I try to enter my apps section it takes me at least 3 try’s to get in it reboots my device very frustrating I submitted a ticket and they said it will be in the software patch upgrade this week and that was Sept 8-2018 and I’ve checked the update on my device and still no update
    There I finished venting lol
    Regards
    Marko:smiling_face_with_sunglasses:
  • I got the W3 antennas and connected they show a link speed of almost 900mbps but doing a speed test I only get 125mbps and with the vpn on I get 65mbps
    It is sad that these boxes can not take full advantage of speeds we are paying for in my case 250mbps.. Closest box I found that actually gets over 200mbps is the S12 Pro Android box wish i could get formuler software on it...
