[pdf]https://www.formuler-support.tv/index.php/Atta…Leaflet-F1-pdf/[/pdf]
Common features of this DVB receiver |
| * Super Fast Mips Dual Core CPU with 1300 Mhz / 3000 DMIPS |
| * 2 x SAT Tuners Fixed and 1 more optional tuner slot for SAT, or Terrestrial / Cable Reception |
| * Powerful Compatibility through Embedded Linux OS |
| * Recording & Playback with External HDD (E-SATA or USB 2.0 Devices) |
| * Recording and Time Shifting Simultaneously |
| * Three USB 2.0 host ports (for MP3 Player & JPEG Viewer) |
| * Powerful Extended EPG support with Event Recording |
| * On-Screen Display with Full Color & Resolution |
| * Favorite Service Groups |
| * Powerful Service Control by Favorites, Lock, Skip, Move and Delete |
| * Service Sorting by Alphabet, Transponder and CAS |
| * User Friendly & Multi-language Supported (OSD & Menu) |
| * Teletext / Subtitle Supported* Maximum 10,000 Services (TV & Radio) Programmable |
| * Picture-in-Picture (PIP) Supported |
| * Parental Lock / System Lock / Installation Lock |
| * HDMI Video & Audio Output (576i, 576p, 720p, 1080i, 1080p) |
| * 10/100/1000 Ethernet port for network connection |
| * Component(Y/Pb/Pr) Video Output via RCA |
| * Composite(CVBS) Video & Audio Output via RCA |
| * Optical Output for Digital Audio(SPDIF) |
| * 2 Smart Card Reader |
| * 1 Common Interface Slot |
| * 1 SD card Slot |
| * Software & Service channel data upgrade via USB & RS-232C port |
| * Under 0.5W Stand-by Power Consumption |
For the use of DVB-S/S2, Satellite tuner only |
| * Supports MPEG4 /MPEG2 - HD/SD and Fully DVB-S2 /DVB-S Compliant |
| * Intelligent Blind Scan for both SD and HD TV & Multi-Satellite Search |
| * Multi-LNB Controlled by DiSEqC Control Version 1.0, 1.1, 1.2 and USALS |
For the use of DVB-T2, Terrestrial tuner only |
| * Supports MPEG4 /MPEG2 - HD/SD and Fully DVB-T2/T/C Compliant |
Hardware Specifications |
| CPU | BCM7356B2 |
| SoC | 45-nm |
| Mhz | 1300 |
| Cores | 2 |
| OpenGL ES | 2.0 |
| Smartcard Reader | 2 |
| Common Interface | 1 |
| Tuner changeable | 1 x PNP Tuner DVB-S2 or DVB-C/T/T2 |
| Tuner not changable | 2 x DVB-S2 |
| Nand Flash | 512 MB |
| DDR3 Memory | 1 GB |
| HDD | 0 |
| e-SATA | 1 |
| USB 2.0 front | 1 |
| USB 2.0 rear | 2 |
| LAN (max Mbps) | 1000 |
| HDMI | Yes |
| YUV | Yes |
| SCART | 0 |
| S/PDIF (optical) | Yes |
| RS-232 | Yes |
| SD/MMC CARD | Yes |
| Size (W-H-D) | 260mm x 55mm x 210mm |
| Display | VFD (8digit) |
| Power Supply Adaptor | Yes (12V - 5A) |
| Power Consumption / Standby | Max.60W / Max.0.5W |
