mytvonline2 Xtream Codes Api
  • ok I need to know if mytvonline2 can use Xtream Codes Api? I was told it could and it worked but somehow I was blocked by my provider nd there telling me mytvonline2 cant be run this way
    it works, but some providers have low thresholds for request rate flooding detection and you will get banned if using mol2.
    the devs are aware of the issue and it will be fixed in the next release.
    the current workaround is to use MAC or m3u supplied by your current provider. or use xc api, but avoid using the grid epg until the issue us fixed
