Hello, I have a connection problem with the server on Z7 +, the connection bar goes up to 100% but can not access TV channels since yesterday. But the VOD it works.
Mytvonline
- MYTVOnline1
- Z7+
Bruno Rodrigues -
March 22, 2019 at 3:19 PM -
did you try your list and channels on another device? maybe your provider has problems?
I try another provider on the same Z7 + and it works. I contacted them they tell me that there is no problem at home and it works with their Z7 +.
Will there be an update mytvonline to correct this because before it worked very well?
Hello, i have the same problem, only VOD work, live tv dont show any channels
I try in stbemu the channels load and work
I think mytvonline need to be fixed
Some one can help me please or any idea!!
I am in the same state as you, it will be necessary to wait for the update of Mytvonline that will leave in March / April
i am sorry i dont know where the problem could be.. -.-
BRUNO and Sofiane
How do you connect to your provider? Registered MAC/Stalker portal, XtremCodes with login and passwort or M3U list?
Did you try to factory reset the box, insert the url and tried again?
Installed update is the latest for Fw and Mol?
I am connected with Mac portal. I already made 2 complete reset of the box but it does not change anything. Currently I also have a Z + that worked and there the same problem impossible to connect
If he will have an update in April, can he have a beta version to use the box?
When the Beta goes Online, info will be posted in forum. Then can you install beta and use.
Sam can you tell me when the beta will be online?
Read my last post over yours, when i get the info this will be posted in forum.
hello, problème solved live tv work
Thx you team
And what was now the reason? Would be nice to know for other users.
i dont do anything,
My provider contact formuler team and solve problème with them
screen
Ok, thx but there was not any update today for Z7+. How ever it works, great.
Picture removed, because of full name inside.
