Im seeing the message m3u error code 11 every morning, it says I'm connected and I can see the epg is working fine but no picture I know it's not my supplier it's a problem with the z8 software, is there an update coming anytime soon to solve these problems as the March update has not solved all the issues people are having at the moment, I think it will be a great product but these issues need to be sorted as soon as possible.
Mytvonline2 m3u error code 11
What kind of URL are you using? With m3u_plus or without? Providers have sometimes more then one URL, did you try also other?
Hi
I have also ”error code 11” but I cant even get it runing, I´m using m3u_plus URL.
All input is apreciated.
Hi
Hi Mr Magoo.
At the end of the url try changing the type, after...
type=
HLS (with options) - m3u_plus&output=m3u8
MPEGTS (with options) - m3u_plus&output=ts
RTMP (with options) - m3u_plus&output=rtmp
HLS (simple) - simple&output=m3u8
MPEGTS (simple) - simple&output=ts
RTMP (simple) - simple&output=rtmp
Display More
Hi Mr Magoo.
type=
Thank you for the input👍.
No problem, let us know if any/varied worked for you or not 👍
