Z8 MOL 2 Issue with TV Catchup
  • Hello,
    I have the same problem someone posted a few weeks ago. I just purchased the z8 and I have a z prime also. I am using the same exact portal but on my z8 I can not scroll/fast forward/rewind the live tv catch up recordings. Movies work fine just the TV catch up recordings on the Z8 using MOL 2 have this issue. I did try the same exact portal on the z prime and it works fine there using MOL 1. Can someone please help and come out with a fix? Just like person said in past post the tv catchup recordings show the timer/duration of the program is shown as 0:00:00, just like his picture which is weird. I know 100 percent this is a z8 Mol 2 issue since it works fine on the z prime Mol 1. I can send a video tomorrow if needed to clarify. Basically I can't watch none of the prior TV catch up recordings since I like to rewind and skip and this a major feature that needs to be fixed since it works fine on z prime MOL.
  • Hello,
    Verified as known issue. Already patched by the developers. Fix will be included in the June release.
