Guten Tag,
Mein Server unterstützt die funktion „sendung in der Wiederholung sehrn“
Finde aber in dieser app keine Möglichkeit.
Würde mich um meine Hilfe sehr freuen.
Lg
Guten Tag,
Lg
Please in English, so others can understand, thank you.
Catchup is possible, how are you connected with your provider? MAC/Portal, Xtreme Codes or M3U?
I‘m using the M3U and my server provide the function to look the channels in repeat.
But I can‘t find it in mytvonline...
Maxbe you can help me?
Best regards,
Max
Best regards,
Max
In your m3u line you can find user/pass and use that to connect to XC instead for m3u.
You mesn to I should to click on: add portal?
But I know only the m3u link...
How to use MAC/ID portal, Xtrema Codes Api (XC) and M3U Url on Formuler Boxes.
I know, but I have only the m3u links
Please read carefully, you need only to extract the needed data from your M3U!
Let`s assume provider give you m3u data for example: "http://xtremec.com:1111/get.php?username=11111&password=22222&type=m3u_plus&output=ts".
To use the data from M3U for XC connect you only need this:
Portal Nickname (example): XC_A
Portal URL: "http://xtremec.com:1111"
Is the login required?: yes, please activate.
Username: 11111
Password: 22222
thats all.
And with other app like progtvmagic it is possible to warch channels in the repeat (only with m3u)
And my provider provide me only the m3u link
please read my post, it is easy to do, costs you only 1min. and you get what you want!
lol why do you have to mention now some third party app when SAM exactly took the time and explained to you everything in details what to do.
Send me pm, calling here on forum conversation.
okey, have sent you pm
Just for Info.
No solution in this case because his provider use optimised M3U url for their app, no standard url. MOL2 works nice with this M3U URL but don't support Catchup in Playlist. Second, XC is also not supported from provider.
Only solution to use Catchup in Mol 2 with this sub is to change to MAC ID/ Portal to get Catchup or to use Providers App and existing M3U url.
