Error when attempting to connect to MOTV2
  • Greetings,
    Currently on Z8 running the latest BETA that was released on Aug 30th. I normally connect to my provider through XC Portal, but also run m3u on it + experincing issues with both. After exiting MOTV2 or restarting the Z8, then opening up MOTV2 it attempts to automatically connect to my last "Connection" (usually Portal) however, recently it loads to 10% then populates 1 of 2 errors; either 1) stating Portal URL error 7 + to check the URL or 2) Check Portal URL: error 7-400 HTTP Error... I have verified with my provider that this is not their issue, this appears to be an issue with MOTV2 as I can still connect to the my provider via "TiviMate" app or my providers own app on my Z8, as well as their web app on my laptop while the issue with MOTV2 is happening.. I have also verified that my URL for my provider is correct. When searching my Portal URL it tells me "Access Denied". Attempted to reset to Factory Settings this morning + still experiencing issues. Does not matter if I am connected to VPN or not. During certain times I can log in without issue, but it's becoming more frequent that this is happening. Any suggestions would be appreciated
  • Update: I powered the device off earlier when I posted the original message + was away for a few hours.. as of 4:35pm ET I have been able to log in + out several times without issue. Idk if it was just a fluke on my side or what may have been going on since only MOTV2 was affected.. Sorry to keep posting in the forum, but issue as of the last 3 hours appears to have been resolved. Thank you!
  • 1. Reports about Beta bugs, issues and feedbacks should be only posted in one official Beta thread like this -> Beta hotfix: Firmware 1.4.25 / Mytvonline 2 software 7.2.3 for Z8.
    2. And.. of course this feedbacks should be posted in the time of current beta status, so the devs. have enough time to fix it or change something. Therefore is important always to read first post and red text..
    3. Spreading such issues in other threads ( like this) with installed beta firmware and software, just confuses other users and especially new users.
    4. Beta is beta and not always for productive use, only for testing and giving feedbacks. If this works nice, perfect. If not, then the devs. need (with given feedbacks) more time to fix the issues.
    If Beta installed, please use only official beta thread. Thank you for your understanding.
    Thread closed.
