ok problem is solved i took a subscription of 4euro/month which entitles me to use faster servers and that solved the problem
what the heck for 4 euros
All the difference between the free and the paid
yes but
i have a dedicated ip on torguard also and that is a 10GB server( i am going to try this into the chrome extension on the box )
Hi.
Kindly note for streaking you have to use the Streaming IP addon which is a fixed IP, this is a 10GB server so should be fast, are you connecting on xxxxxxxx``3 just now ?
Let us know if you have any further questions.
Regards
Mike
Keep us informed![]()
i cannot configure the connection to my dedicated ip on the box , the torguard app is no good due to the android os version on the formuler i think
we will see what happens next , are they going invest time in this ,
who knows, so i use PROTONVPN now minimal payed subscription
Keep us informed
yes mdr : keep us informed![]()
You mean where to get vpn access account? Just browse the web and search for express vpn or nord vpn, subscribe and you will get Android App from this vpn to install on your box.
i am happy with PROTONVPN, 4 euro/month and the interface is very clean on the app.
In the app you configure : start app on boot of iptv box.
Further No startup app like WOL2 needed .
It's really clean and easy
Thanks SAM.
Hello, i use ExpressVpn and depending on which server i'm connected to I get black screen on tv Z7+5g so Mol1 ?
I tried 4 servers and only 1 is working but all of them had a good connection like up to 60Mbps.
Which setup config do you recommend ?
Formuler456 my 2 cents on this:
There are too many possible/potential different "router hardware"/"internet provider"/"iptv provider"/"vpn provider" combinations to be able to give 1 advice that always works.
1) Use what works for you.
2) Free/Cheap VPN (and IPTV) is usually not the best. Neither is the most expensive a guarantee for quality.
3) Internet providers are potentially constantly changing their networks, so what works today might not work tomorrow.
I also after the last updates in formuler lost the settings option to torguard.
Can anybody help?
Thank You
I have tried using free VPNs too and then passed to paid version... And I have to say there is a lot of difference! The main difference is the speed. Free version always having bad connection and sometimes gave errors.
