Hello. Maybe you are aware of this already and it will be fixed.
It is annoying when watching timeshift (e.g., 15 minutes behind live TV) that the OSD (blue bar at the bottom) does not hide after a few seconds, so if I fast forward through adverts the bar remains. Then sometimes I press "back" (wrong button I know) to remove the OSD (like you would when watching live TV to remove the OSD) only to find MYTV changes channel to the previously watched channel, now I have lost the last 15 minutes of channel I was trying to watch, so no ability to rewind 20 minutes to where you were just watching.
I hope this is on the to-fix list? Pressing back should probably not go to the last viewed channel and cancel your timeshift viewing by mistake. It is way too easy to do it by mistake especially because normally pressing "back" is to remove the OSD/EPG etc, and that the OSD does not auto remove/hide when viewing timeshift!
Why can't a different button do that (switch to previous channel), something far away from an easy pressed button to do it by mistake. Also as many people in the UK are used to Sky box using blue button to go to previous channel.
Thank you
