My tv on line tv - epg not work
epg
Please provide all detailed and needed information from your box, so we can try to understand why this happens on your side.
With "My tv on line tv - epg not work" we can not even start to research, because of missing important informations!
1.Fw and sw version?
2. Since when does this happen?
3. Does it work earlier?
4. Connection type: Stalker ID/MAC portal, XC Api portal or M3u playlist.
5. etc...
habe die Box 2 Tage,
V1.4.46
Ich glaube m3u Liste
Es betrifft nur teleclub Sender
Alle anderen Sender funktioniert Epg
Please in English. Thank you.
Must be provider dependent, not all channels worldwide have epg in such subs. For recheck, install other iptv app like tivimate and test there.
The epg of teleclub Sender goes in smart iptv app
The Smart iptv app has it's own epg data.
then the fault lies with the iptv provider and not with the mytv ap
Tested with Tivimate App and same result like with MOL2, all other channels have epg but TC not. Is not MOL2 issue.
there is also a forum for the Formuler z8, in German
It was at beginning, but the forum language changed to English only, so all others can understand written.
Thanks for the help, and quick answers. I still have a problem. my universal remote control cannot be connected to the Formuler z8, TV is a Qled from 2019, Q85r
