I’m having an issue with my EPG offset where lt keeps drifting out by one hour and I have to keep adjusting the offset.
Usually by putting it on UTC and going +1 hr or going back to 0 and clearing epg data sorts it out, but I have to keep doing this.
Today I’m not able to correct the problem as certain channels are synchronised but others are not.
I’ve checked using different IPTV apps and it displays properly in them so think this could be a mtvol2 issue?
I’ve also had issue where pressing the ok button displays the correct information but pressing the epg button does not
