Just tried to open my MYTV ONLINE, now saying Invalid Parameters. Strange because I was using my Box 3 hours ago.
So what can I do to solve the problem...???
Cheers in Advance
Popeye05
Cheers in Advance
Popeye05
Repyling to my own thread now.
Just done a reboot on my Box and all OK now, so I don't know why is stop working and saying Invalid Parameters.
Could anyone Answer that one please.
Plus all weekend had no end of problems with my Provider, in the end they sorted out all my channels issues etc etc...
Nothing would work had all my EPG working showing all Channels then a BLACK screen...
So now resolved...???
Cheers
Popeye05
There are so many variables... Z7/Firmware/MOL/JVM/Network/Routers/VPN/Subscription/Provider/etc... Especially when it is resolved and when it cannot be reproduced after a restart finding a root-cause is very unlikely.
Hi ddd,
True, I have had some Bizarre stuff happening lately with my z7+ box.
But now all seems fine now...
Cheers
Popeye05
Hi ddd,
Gone down again, getting p****d OFF with this now.
My provider sent me a link so I can use on my Laptop also which yes works ( they said if OK on there it must be
something at my end ), but still glitches a lot...
So could you help me with my z7+ box please...
Why does it work then stop again bizarre ???...
Could my internet provider be trying to block, if so what do I do.
I thought I had everything OK there because MYTVONLINE has been fine for the last year apart from recently.
Thank you in Advance for your HELP
Popeye05
If you are not using VPN yet I strongly recommend that. Even if you do not have issues. But for sure it can cause strange issues like this and black screens etc...
Hi ddd,
Been using VPN for a few years now, even my provider asked because of different setting etc.
You won't believe this EVERYTHING BACK & ALL WORKING AGAIN...???
THIS IS GETTING STRANGER BY THE DAY...
Cheers again ddd
Popeye05
