Well, the layout on my EPG has changed. Now I have to load EPG in the side view, because I cant see it in the program view. (The first you see when you press the centre button)
And after I loaded it in the side view it doesnt get updated back in the programview.
So, it seems like some program code has changed from how it was before....
Anyone knows the reason for this?
And when it eventually will be fixed ?
And if that wasnt enough, there are double entries on every program in the side view. Like a shadow copy. Same hour and same text. Thats not necessary, is it ?
Thank You
/Zappa
