Sam...
Can I buy external Hard drive like a Seagate or WD to plug in my Z8 to record live Shows?
If so do I need to format the External HD & what format?
I know I've seen this somewhere on this forum just cant remember where at.
Thanks Sam.
Sam...
Thanks Sam.
Yes
Yes, best is NTFS. Here is the how to -> How to format Micro SD card, USB flash drive, pen drive, hard drive or SSD for use with Z and S Boxes.
Each time when you post something, you can see in header the blue window. at 4. stays Instruction Articles.
Appreciate Sam 👍
Can External HD be moved to say a PC & play directly from files collected? Would I need to have a particular player to use say on PC ,laptop?
If you mean to watch recorded ts files from your Formuler box on pc, sure it`s possible. Each player that works fine with .ts can play such files.
Thanks Sam.
Yeah was was thinking of getting external HD with some good beef on it like 2tb so wont have to worry about space.
Not sure what sort of memory I would need to record say a 2hr movie but dont want any issues with Space.
I think it's about 1gig / hour recording HD but i could be totally
wrong lol
This depends always from stream and how much the bitrate is. Higher bitrate means bigger files.
Many of IPTV content is with lower rate (SD) and doesn`t need to much, HD 1-3GB for two hours and more for 4k. What i see is iptv HD is not always real HD (like on Sat. box with constant bitrate) and need then not so much space. How ever, at end this depends from user how much he record and delete. I record very much on my main boxes (delete too) and in most cases only HD or 4K content, but all hdd`s are lower than 1TB ![]()
My brother-in-law mentioned a little problem with his new Z8 using an external hard drive.
His hard drive goes to sleep within 30 minutes or something, so it will never record anything after that time.
We can't find a setting to turn off the sleep mode.
Any ideas?
This is set in the firmware from his hdd, therefore the hdd goes alone into standby. Each hdd manufacturer have tools to change such power settings. Check the website from hdd manufacturer and search for maintenance tool.
Thanks SAM that's what I will do.
