Is it possible to save a recording to a folder on my onedrive?
If so, how do I do that?
I think you have to connect to box via explorer and move files
Trough windows explorer and type in PC explorer //ip.xxx.xxx.xxx/share
Ok, Can I transfer my recorded files somewhere to make them available on my pc or my iPhone?
The recorded files are on my usb, but I take it that they are in a format that cannot be played on a pc
\\ip.xxx.xxx.xxx\share is correct
I made this mistake once in another thread.
Why not, you just need some player that can read ts.files and all associated files from folder recordings.
Thanks for your answers, but I don’t quite understand how I would be able to save a recording to a one drive folder. Would anyone like to explain it more carefully?
copy to folder on one drive from from recordings on box
Hi, I think the OP mean that the recording shall be saved direct to one drive, and not first to the F8->Usb hard disk... and copied from there
so, How can I record direct to One drive? ![]()
You can not record directly to one drive, only local.
