I updated using this beta today because I was having problems with ‘Failed to load VOD Data’ error in movies and also in tv shows.
Live tv is just a black screen on every channel when this happens.
I then have to disconnect portal and reconnect in order to fix this problem and everything seems ok again.
After the using the beta the problem still persists,
Is anyone else experiencing this problem or knows what I can do?
I’d appreciate any help thank you
